help with (T428 BN7B11) component
Discussion in 'General Electronics Chat' started by engwas, Jan 9, 2009.
  1. engwas
    Jan 9, 2009
    18
    Hi
    I have electronic component and did know what is it, it a 3 pin with this (T428 BN7B11) write on it, it found in Inverter 12 to 220v and I search in internet but did not found any thing useful pleasse any one help
    thanks
  2. mik3
    Feb 4, 2008
    4,846
    63
    Are you sure this number is correct?
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Can you make a scharp photo of the component ?
    That also shows the shape and an idea of its size.
    Greetings,
    Bertus
  4. engwas
    Jan 9, 2009
    18
    Hello
    Yes this number on it
    T428
    BN7B11
    And see it photo
  5. mik3
    Feb 4, 2008
    4,846
    63
  6. engwas
    Jan 9, 2009
    18
    Hello
    It read short in all pins and i must replace it and it make fuse damaged so i need to know what is it to buy a new one one
  7. mik3
    Feb 4, 2008
    4,846
    63
    I have read that you found it in an inverter so I think it is a MOSFET used for switching. They use special thyristors (called GTO's-gate turn off) for switching too but MOS are more usual. Take a photo of the inverter to see where the device was connected. Also, try to see what othe devices were connected to it.
  8. engwas
    Jan 9, 2009
    18
    hi
    Its 4 and every 2 are connect to transformer and some resistors after 12v battery
  9. engwas
    Jan 9, 2009
    18
    Hello
    T428
    BN7B11
    And see it photo
  10. mik3
    Feb 4, 2008
    4,846
    63
    Can you identify the control part (controls the device you took out) of the circuit?
    If yes, what is it?
    Are there any resistors from the output of the controller to the broken device? What value?
  11. engwas
    Jan 9, 2009
    18
    i did not understand what do u mean
    Please i just need to know what is it to replace it
  12. mik3
    Feb 4, 2008
    4,846
    63
    From the part number we can't get anything useful. To find what it is you have to see the connections around it and so on.
