help with switching
Discussion in 'The Projects Forum' started by smith bond, Mar 14, 2008.
  1. smith bond
    Mar 14, 2008
    dear friends, plz help me design a simple electronic switch which is ON if the input voltage is in the range of 1.5volts to 2.0 volts and turns OFF if the input supply not in the above range.
    thankyou.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Although your request is somewhat similar, it's not quite the same as the O.P.'s original request. It is best to start a new thread in such circumstances.
    However, see the attached; one-half of an LM339 comparator IC is used, along with some resistors, a couple potentiometers, and a Zener diode.
    The inputs of the unused comparators should be connected to ground.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What the Sarge has provided is called a "window comparator." Using that exact phrase in a search will turn up additional ideas.
