I have a question about the way this circuit works:See if this circuit works for you. Q2 and Q3 have to be 1000V rated.
Actually I am wondering about the orientation of the two mosfets, I think the current will flow from drain to source in Q3, and then the current will enter Q2 from the source going to the drain (oppesite direction) which will cause negative drain to source voltage. I am wondering if the two mosfets need to be in the same direction (current enters both mosfets from the drain and exit from the source).Both Mosfets are of the same type (n-channel). I am replying on my IPad and I do not have the circuit in front of me, but both MOSFETs are N channel and require positive gate voltage with respect to ground to turn on. Once you apply positive voltage to both gates, the MOSFETs will conduct current from an external source, even though there're is no common ground between the local gate control voltage source and external 1000V supply. If I understand correctly you are a little suspicious about the circuit because there is no common ground between your 1000v source and the gates control voltage. Let me know if my assumption is correct and I will try to explain that.
Yes would be perfect but would also double the number of FETs necessary for each direction.Wouldn't an H-bridge, using drivers for the mosfets be a better way of doing this? Unless I missed it the -1000V and the +10V aren't on at the same time. Each side of the H-bridge would allow the different voltage to return to its own circuit.
A driver like this - http://www.irf.com/product-info/datasheets/data/ir2213.pdf - has its own separate ground for the "logic" side and the high voltage (com) side, that don't need to be connected to each other.
I was the told the duty cycle is about 20% most of the time, but it could vary.Yes would be perfect but would also double the number of FETs necessary for each direction.
I still prefer something like thisbut it also requires two isolated gate drivers and therefore two additional power supplies. You could also use transformer coupled gate signals, they are isolated and don't need an additional power supply but this doesn't go well with the non-50% duty cycle.
The circuit from post #12 may cause excessive switching losses as the FETs are turned off through the 4k7 resistor.
I don't know why the OP is concentrating on only the -1000V if it is actually +10/-1000V he wants to switch.
You could actually use the 100kHz gate signal to generate a secondary power supply for an isolated gate driver. Is the duty cycle fixed or variable?
I actually considered using that H bridge, but to be honest I only used H bridges once in my life to control a DC motor, I really dont have a lot of experience of using them as power switches. The application circuit listed on the first page of the data sheet looks little confusing to me, because the load is connected between two mosfets, not between one mosfet and ground like I am used to.Wouldn't an H-bridge, using drivers for the mosfets be a better way of doing this? Unless I missed it the -1000V and the +10V aren't on at the same time. Each side of the H-bridge would allow the different voltage to return to its own circuit.
I don't see an advantage.I actually considered using that H bridge, but to be honest I only used H bridges once in my life to control a DC motor, I really dont have a lot of experience of using them as power switches. The application circuit listed on the first page of the data sheet looks little confusing to me, because the load is connected between two mosfets, not between one mosfet and ground like I am used to.
Can you direct me to any material that could help me understand H bridges circuits?
Also, it doesn't really matter how many MOSFETs I will end up using, as long as it works.
I like the idea of using that H bridge very much..Wouldn't an H-bridge, using drivers for the mosfets be a better way of doing this? Unless I missed it the -1000V and the +10V aren't on at the same time. Each side of the H-bridge would allow the different voltage to return to its own circuit.
Now what happens is that the Load resistance , the 10V supply and the -1000V have all different reference voltages. This is what I posted a few pages before (maybe in the other thread). It doesn't matter in which direction you apply the voltage to the resistor if it is not related to the power supply reference voltages...
It's kind of confusing what you want to achieve.
Maybe we can start all over again?
1. Are the 10V and -1000V isolated from each other?
2. Does the load have to have the same reference as one of the power supplies?
3. Does the PWM have to have the same reference as one or both of the power supplies?
4. Maybe you should ask for more details of what the customer has/wants.
A few solutions have been given to you. I don't see where the problem is.
Actually, I understand that concept, and I use it to switch the positive supply, its the negative supply that is giving me hard time.Once you apply control voltage to both MOSFETs each MOSFET will establish a conductive channel between drain and source or source and drain. This conductive channel will conduct as long as control voltage is applied (Vg-s > Vth of your MOSFET). One thing to verify though is that the in ternal resistance of your selected MOSFETs has to be 10 times lower then the load resistance. Rds(on) << Rload. If you can get hold of MULTISIM simulation software you can test this circuit on your computer.
Mmh, it didn't seem to be what you wanted in the beginning. If the PWM is isolated and you only need to switch -1000V then just connect the PWMs ground to -1000V.3- The PWM is a third supply that has its own ground, it doesn't matter if its ground is tied to the two power supplies (+10, -1000V) ground or not.
I need to be able to switch the -1000V supply using a low side switch (negative supply connected to the MOSFET source, and the load between drain and ground, as in the little circuit that I posted in the beginning of the thread).
That is exactly what I did to switch the negative supply, but didnt work. I think it takes more than that to do the switching of NMOS with negative supply.Mmh, it didn't seem to be what you wanted in the beginning. If the PWM is isolated and you only need to switch -1000V then just connect the PWMs ground to -1000V.
What about the 10V?
That is your problem. A mosfet is bidirectional in regard to polarity. For your negative 1000V side, the -1000V goes to DRAIN and the source goes to the positive "ground" of that supply. This link at the very bottom of the page gives an example of what I'm talking about(even though they show a motor) http://www.electronics-tutorials.ws/transistor/tran_7.htmlActually, I understand that concept, and I use it to switch the positive supply, its the negative supply that is giving me hard time.
when I connected the negative supply to the source of the mosfet, and connected the load to the grain and then the other side of the load is grounded, I noticed that no matter what you do to the gate (grounded or connected to +5V) the mosfet is conducting, it only opens when you leave the gate floating (like shown in the schematic I posted in the beginning of the thread).
So my question is, how to switch the -1000VDC on and off without leaving the gate floating.
Also, the gate is tied to the -1000V with 1Meg ohm resistor, that negative voltage connected to the gate is what prevents the mosfet from conducting (push the electrons away from the channel so it doesn't conduct), when you ground the gate, there is no force to push the electrons away, so they get pulled up and they form a channel and they conduct when the gate is grounded.
I say mosfets are bidirectional because they can be used to switch AC voltage.
This all would be easier if you would identify the whole "non-secret" circuit. Or even the component that this switch controls.
I dont think mosfets can be used to switch AC directly, because they are uni-directional (check out this source http://www.irf.com/technical-info/designtp/dt94-5.pdf)
There is really something wrong in the way you look at MOSFET switches. First of all if you connect a resistor from gate to source , it is not floating. Having a floating gate means it is not connected to anything.The only way to turn the transistor off is by connecting a resistor between the gate and source and leave the gate open/floating. once the gate is connected to ANYTHING (+15V or even ground) the FET will turn on and conduct..
by Jake Hertz
by Jake Hertz
by Duane Benson
