Help with Super White LED Dimming Circuit
Discussion in 'The Projects Forum' started by worlda, Nov 9, 2009.
  1. worlda
    Nov 6, 2009
    7
    Hi I am looking for some help with a Dimming circuit for a LED board I make for a Video Lamp Here's is the info on the LED used
    Super White LED Specifications:
    Size (mm) : 5mm
    Lens Color : Water Clear
    Reverse Current (uA) : <=30
    Life Rating : 100,000 Hours
    Viewing Angle : 180 Degrees
    Absolute Maximum Ratings (Ta=25°C)
    Max Power Dissipation : 80mw
    Max Continuous Forward Current : 24mA
    Max Peak Forward Current : 75mA
    Reverse Voltage : 5~6V
    Forward Voltage : 3.0-3.2V
    I used 96 LED's 4 LED in series will have a 120ohm resistor Each row so 24 rows 24ma per Row
    I am using 15V 2 Amp Power supply
    Can anyone help with a Dimming circuit for this unit thanks much for any help Charlie
  2. MikeML
    Oct 2, 2009
    5,450
    1,066
    You just need a variable 1A power supply that is adjustable from ~12V to ~16V. Almost any DC regulated power supply, linear or switcher, would work.
  3. BMorse
    Sep 26, 2009
    2,675
    234
    you would be better of using a 555 timer circuit to PWM your LED's through a Mosfet, then you can vary the 555's output to dim/brighten your LED's..... this will also lengthen the "life" of your LED's, instead of keeping them constantly "on"....
    My .02
  4. sstbrg
    Nov 29, 2008
    54
    I'm with BMorse.
    PWN is also popular with motor controlling.
    Here's an example of how to configure the LM555:
    http://www.ledmakers.net/show/?id=152
    Pretty much self-explanatory form here, just add the MOSFET part.
  5. iONic
    Nov 16, 2007
    1,422
    68
  6. worlda
    Nov 6, 2009
    7
    thanks all
    does the 555 PWN works with a 15V PS??? or she I use a resistor to lower the voltage to the PWN
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Absolute maximum Vcc is 18v.
    Most datasheets for 555 timers give specifications at 5v, 10v, and 15v.
  8. worlda
    Nov 6, 2009
    7
    Any I dead which Mosfet would be best needs output 2.2amps 96LED at 3v 24ms
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Any standard N-channel power MOSFET rated for Vdss=30v or more, and at least 5A Id (drain current).
  10. worlda
    Nov 6, 2009
    7
    Thanks all for the info one more thing if I want to your Battery,Cads to drive this circuit 12vdc 2.2amps any Ideals on circuit and battery?
