Help with SPDT Switch MASW-000936
globalone
Joined May 27, 2013
22
I am building a bi-directional amplifier and I am trying to integrate the SPDT Switch MASW-000936 into the circuit, but I couldn't find a Logic Driver for this switch.
Does anyone have an idea of something that would let me control Logics input -15v / +15v ?.
This is the link of the Switch
https://www.macomtech.com/datasheets/MASW-000936.pdf
your recommendations are much appreciated
Ghassan
globalone
Joined May 27, 2013
22
What is a bi-directional amplifier?
Bi-Directional Amplifier is :
An Amplifier with 2 ways using the same frequency channel , including the Low Noise Amplifier for the Receive and the Power Amplifier to transmit . The switch is to isolate between the LNA and PA .
globalone
Joined May 27, 2013
22
I am receiving signal and transmit signal at frequency 2412 MHz using half duplex (Time Division) Duplex. This amplifier should boost the signal of any WiFi Router.
I only want a logic driver which could send to the switch , for example : Logic 0 with -15 V pulse and Logic 1 with +15 V.
