Help with sound amp
Discussion in 'The Projects Forum' started by Emerican_360, Nov 15, 2007.
  1. Emerican_360
    Nov 15, 2007
    I'm just starting out with electronics and I've found this diagram of a battery powered sound amp. I thought this would be a cool project to do for my guitar. I'm only in grade 9 and I've learnt about ohms law. I can read switches and resisters off a circuit. Other than that I'm stuck!
    Please could someone help me with the layout of the circuit and tell me what are the exact parts that I will need.
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The circuit is built around an "LM386 low voltage audio power amplifier." You can read about the chip here:
    http://web.mit.edu/6.115/www/datasheets/LM386.pdf
    This is really just an "operational amplifier" optimized for a given task. You can read about operational amplifiers here:
    http://www.allaboutcircuits.com/vol_3/chpt_8/index.html
    In addition to resistors, the only other components in the circuit are capacitors. Learning about capacitors takes a little more effort than learning about resistors. See both of the following:
    http://www.allaboutcircuits.com/vol_1/chpt_13/index.html
    and then
    http://www.allaboutcircuits.com/vol_2/chpt_4/index.html
    You'll should also begin learning how to solder.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    This could be somewhat difficult if you don't have the means to make a printed circuit board. An alternative would be to go to www.circuitspecialists.com and get a bus strip to breadboard the circuit on. Their #WB-102-1+J is only $6.49. They have small parts, too.
  4. studiot
    Nov 9, 2007
    5,005
    515
    The 386 or any audio amp capable of driving real speakers is similar to but not the same as an operational amplifier.
    Look here to find a fully worked out project using a 386 from a 9 volt battery.
    http://www.talkingelectronics.com/projects/MiniBenchAmp/MiniBenchAmp.html
