i have never solved a circuit with diagonal node. .89 ohm on top, 1 ohm on right, 4 ohm on bottom, 2 ohm in middle and 10 volts on left. plus i have to solve using KVL and KCL. i have only found for multiple volts not one. any help would be appreciated. I did redraw the circuit to be parallel-series and got total as 2.01 as current. like i said the teacher said find by using KVL, totally lost.
put this together for the site along with http of course
yfrog.com
/140409001802j
yfrog.com
/140409001802j
