Help with Solid state relay
dionysian
Joined Jun 26, 2007
I am trying to control a Opto 22 240D45 DC Control solid state replay with a micro controller. However before I hooked it up to the micro controller I though i would simply apply a DC voltage to the control input. I was expecting that in doing this the output (pins 1,2) would be short together. However when ever I do this no matter what DC voltage I apply the output pings never short together.
I am misunderstanding what this relay is suppose to do?
Below is the schemtic of the interal of the relay:
See attachment
It is my udnerstanding that just as long as I hook up a 3V or high voltage to out 3,4 then pin 1,2 should short???? is this incorrect.
In the data sheet it says the Signal Pick-up voltage" is: 3VDC(32V allowed).
when I adjusted the controll voltage V34 the resistance between 1,2 does change but not much. I was expecting to go short.
What I am I doing wrong? What I am I not understanding?
MikeML
5,444
The output will only "short" if connected to the AC line in series with a load. You cannot see the "short" with an Ohmmeter, because it doesn't put enough voltage across the output pins.
34,408
A DC type SSR with a MOSFET output will show a short across the output with an ohmmeter when turned on but not an AC type, with an SCR output.
If you increase the voltage across the AC output to > 2V (with a resistor in series) the output will conduct with somewhat over a 1V drop. Note that the SCR will then continue to conduct, even when the input voltage is removed, until the output current is reduced to zero.
MaxHeadRoom
Joined Jul 18, 2013
28,681
You might see a change if you have a Diode check range on your meter, as this range provides forward biasing voltage in order to see the conduction of the diode/SCR.
Max.
dionysian
Joined Jun 26, 2007
Thanks guys this makes sense. Before I was able to see the short when using a DC relay, but this makes sense with an AC output relay.
I appreciate the response from all of you.
dionysian
Joined Jun 26, 2007
Max,
I put my meter across the output and used the “diode check function" (thing that looked like a diode on my meter) and I got 1.8... I noticed on the datasheet that there is something called "Maximum output voltage drop" that is 1.6V. Is this what I am measuring? I think so.
this is the forward voltage drop right?
MaxHeadRoom
Joined Jul 18, 2013
28,681
Yes that would be F.D., if it worked, it would be the same in either direction due to the back-to-back SCR's.
In reconsideration, I am surprised it did work due to the resulting low SCR gate current?
Al.
TANDBERGEREN
Joined Jan 20, 2014
90
Anyhow.
At theese extremely low current values Your multimeter is doing it's meassuring, You will not get any reliable reading of the devices actual forward voltage drop.
Check in the datasheet, and You will see there what voltagedrop at wich current value You can except.
