Help with solid state relay
Discussion in 'The Projects Forum' started by lerios80, Jul 8, 2013.
  1. lerios80
    Jul 8, 2013
    I'm trying to run 16v 1 amp ac voltage to an electric strike plate from an ac adapter with an intercom system. I can't seem to find a relay that is rated for under 24 v ac. The controlling voltage will be 12v dc from the intercom panel. If I buy a relay rated for a 24 volt ac minimum will it allow the voltage to pass through? If not can anyone point me in the right direction to find the relay that I need? I would really really appreciate it. Thanks.
  2. Dodgydave
    Jun 22, 2012
    5,144
    768
    As long as the relay is rated higher than your needs it will work .
  3. lerios80
    Jul 8, 2013
    Thanks appreciate it
