Help with solenoid control
Discussion in 'General Electronics Chat' started by Mustang2503, Sep 13, 2010.
  1. Mustang2503
    Sep 13, 2010
    Can anybody help I have around 50 solenoids valves that I want to control along with about 60 lights. I need to create a circuit that I can programme so that the valves will open and close at a given time for a set period and the same for the lights, am I best to use a plc or is there another way of doing this, this type of electronics is completely new to me so any help with circuit diagrams ideas and any other information that may be helpful will be appreciated
    Many thanks
    Matt
  2. Kermit2
    Feb 5, 2010
    3,848
    963
    By control, you mean sitting at a big board and pushing a button to make it work, right? 50+60=110 buttons.
    Or is there more to it that you need to tell us?
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    Allen Bradley makes PLC's that have both time driven sequencers as well as event driven sequencers in their logic. Here is a link for a training CD that will familiarize you with their PLC programming. There is a chapter on sequencers that teach how they work which would allow you to decide if a PLC is your best option.
    http://www.logicdesign.com/inside/plc.html
    There a multitude of Google hits for "drum sequencer" and PLC.
  4. Mustang2503
    Sep 13, 2010
    thanks for your reply i want to set a sequence that will go off every 15 mins using each relay more than once
    thanks agen.
  5. Mustang2503
    Sep 13, 2010
    thanks for your reply this has been very helpfull
  6. majsyd2010
    Member
    Aug 29, 2010
    61
    There are some pre made units especially design for your application where you can use for that high volume of solenoid and lights, the units will give you full range of advanced options such us group on/off, Timers and pretty much anything what you want and thing and also you can create logics and any type of form of condition logic.
    Following are some suppliers
    http://www.cbus-enabled.com
    or
    http://dynalite-online.com/v2/dynalite/index.jsp?lang=au_en
    Don’t hesitate to contact if you need any further info as I been using this all the time. I can create the flow chart if need
    Cheers,
    Maj
  7. marshallf3
    Jul 26, 2010
    2,358
    201
    Modern pipe organ controller?
  8. majsyd2010
    Member
    Aug 29, 2010
    61
    I couldn't really catch your pharse above .... ??? Not sure what do you mean???
