I have this circuit, which works for about an hour and the dies every time I don't know why. When it dies, I have to completely rebuild it with new components to get it to work I designed it myself, which is probably why it doesn't work for long
Basically how it's supposed to work is there are two solar panels (2v Calculator panels) that are used to sense where the sun is. One of them is centered on the solar panel and has a shroud around it which stops the motor when the panel is pointing directly at the sun. By default the motor will go one way until the right hand solar panel is centered on the sun, if the sun is on the other side it powers the other solar panel which reverses the motor direction. There is another circuit (not shown) that turns off this circuit when there is not enough sun, which works.
Anyway it works, but it keeps dieing after a while and I don't know why, it doesn't get hot (not even warm). Basically when it dies it doesn't respond in anyway to the solar panels. The solar panels are 2V and put out around 15ma short circuit. I forgot to put it on my circuit but the top line is connected to +12v (car battery). I think my resistor values may be wrong.
I also built this circuit with 1K variable resistors in series with the solar panels in case they were providing too much current and killing the transistors ? I'm using two SPDT relays in place of the DPDT, the coils need 12V and around 50ma each.
I hope my hand drawn schematic makes sense.
Any help would be appreciated.
