Help with simple smart switch that allows current flow at 14.5v but restricts at 13v
Discussion in 'The Projects Forum' started by jdcproducts, Apr 5, 2012.
Thread Status:
Not open for further replies.
  1. jdcproducts
    Apr 4, 2012
    I am trying to run a load in an automobile but what I really want to activate the load automatically only when the alternator is up and running at its nominal 13.5-14.5 volts dc.
    Before the car is turned on the normal voltage of the battery is usually less than 13 volts, when the alternator is on it can jump to 14.5 volts.
    I need a smart circuit which will not activate or send power until it recognizes an increase in voltage or it detects the 14.5 volts. It will then shut down when the ignition is turned off and the alternator goes offline. Only needs to be enough power to trigger a dc relay.
    What I really want to do is allow the circuit to pass a voltage to a relay which will run the load but will release power from the relay when it sees a voltage drop, in other words turn itself off when the alternator is turned off and the voltage starts dropping down to the batteries normal voltage reading of less than 13 volts dc. It would be more or less an automatic electronic switch that only turns on when the alternator is running.
    I could tie into an ignition wire or another relay in the vehicle but I am trying not to do any modifications to the factory wiring. It would be a small enclosure that is directly connected to the battery and will remain dormant until the car is turned on and the alternator is supplying excess voltage at or around 14.5 volts, then it will pass voltage through to the relay which will actually power the load.
    Any ideas on how to go about designing a simple circuit to do this? Any help would be greatly appreciated...
  2. jdcproducts
    Apr 4, 2012
  3. panic mode
    Oct 10, 2011
    1,328
    305
    jdcproducts likes this.
  4. jdcproducts
    Apr 4, 2012
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Just a simple comparator won't work.
    We no longer support discussions about automotive modification topics per the TOS paragraph 6, so this thread will be closed when a Moderator sees it. The TOS is not open to debate; it was established by the owners of the site.
    I sincerely recommend that you not proceed with your idea; it's far more complex than one would think.
  6. jimkeith
    Oct 26, 2011
    539
    99
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
Thread Status:
