Help with simple LED circuit
Discussion in 'General Electronics Chat' started by noingwhat, Jul 23, 2010.
Thread Status:
Not open for further replies.
  1. noingwhat
    Jul 23, 2010
    61
    Hi! I am pretty new to circuitry (working on my first few projects). One of my projects was an LED flashlight hat. I had wired it up and everything, and it worked great. I used two 9v batteries in series with 5 LEDs in series, meaning each LED was recieving approx. 3.6v each. I have used the LEDs with 6v ea. using two 3v batteries wired in series, and it just made the LEDs really bright so I figured if I added another 9v battery meaning a total of 27v, that would be 5.4v per LED and it would just make it really bright. So I added it in and... It blew the LEDs. All five of them. Can anyone explain why, I do not understand why 5.4 blew the LEDs when 6v didn't.
  2. tom66
    May 9, 2009
    2,613
    214
    5.4 volts is well above the rating of the LEDs (usually no more than 4 volts is acceptable for blue/white LEDs, and no more than 3 volts for others), what colour were your LEDs?
    For higher brightness I suggest the calculator:
    http://led.linear1.org/1led.wiz
    Use 25mA for the forward current, this will make your LEDs glow really bright.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Bill_Marsden is right, one thread is enough.
    Lets continue in the other thread.
    Bertus
Thread Status:
