Haha, yes, you would think that would get their attention.Did the guys from the power company experience the shock too?
If they did I would expect them to fix the problem.
Make sure the electrician understands and has successfully dealt with problems of this nature, then let him at it to see what he wants to do.Electrician is coming on tomorrow and I intend to do the following:
- check all neutral connections in the main panel.
- check all breakers and neutral connections in the pool/hot tub sub-panel.
- totally replace the main panel neutral ground rod and wiring.
