Help with Series RLC
Discussion in 'Homework Help' started by fatboy2131, Oct 5, 2007.
  1. fatboy2131
    Oct 5, 2007
    10
    Hello Everyone,
    I've got a question. I am taking an on-line electronics course, and we have been doing Series RLC circuits. I have a test question (attached) that I am not sure of. Basically, it is a Series RLC circuit with no values (resistor, capacitor, inductor, supply voltage, or current) other than three voltage readings. Can someone out here explain to me how I can find out this answer? I have read twice so far my lessons on this and can't figure it out. I'm sure I'm just missing something or "overthinking' it.
    Thanks!
  2. techroomt
    May 19, 2004
    198
    sorry, it didn't open for me.
  3. ixisuprflyixi
    Sep 16, 2007
    52
    You must be overthinking it. All voltage drops in a series circuit add up to system voltage.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Not true. You are forgetting about phase.
    Here's my take: Since the voltages are equal, and all components have the same current flowing through them, then XL=XC=R.
    Since XL=XC, the circuit must be at resonance. At resonance, the voltage across (XL+XC) will be zero, because voltage across L is 180 degrees out of phase with the voltage across C. Therefore, the supply voltage is 100V.
  5. fatboy2131
    Oct 5, 2007
    10
    :)Nice! Thanks alot!
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    So the AC voltages at the inductor and capacitor cancel each other because they are 180º out of phase (the capacitor is 90º behind and the inductor is 90º ahead)?
  7. Ron H
    Apr 14, 2005
    7,050
    657
    That's correct. Below is a Bode plot of the circuit. It's a little busy, but you can see that at 1kHz (resonance), the voltage across each element is 100V, and the phase across L and C are 180 degrees apart. You can also see that the voltage across the LC combination (V(A,C)) is zero.
    Note that R=100, XC=100, and XL=100 at 1kHz. They could actually have any value, so long as all 3 are equal.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I hate how this forum converts .PNG to .JPG. It screws up the quality of the images, and also shrinks them, making them difficult to read. The other forum I lurk in doesn't convert the image format.
  9. ixisuprflyixi
    Sep 16, 2007
    52
    Thank you Ron, I overlooked that. Hope I didnt confuse anyone.
