help with SEPIC converter. mosfet is unable to turn off!
Discussion in 'The Projects Forum' started by sizzhon, Mar 25, 2012.
  1. sizzhon
    Mar 25, 2012
    5
    hi everyone,
    Please help me with my third year BEng project "Designing SEPIC converter whose output is 5V to 20V and 1A current and also use micro controller as PWM controller (regulator)".
    Problems
    a. mosfet is not turning off.(both in simulation and practical)
    b. snubber circuit which one is the best for sepic converter (i used rate of rise of voltage)
    c. calculation to find the value of inductor(i.e. I calculated the L1 first and then made L1=L2. what happens if we calculate L2 first and make L2=L1?)
    d. ground plane?
    e. Does MOSFET driver necessary for 94kHz frequency ?
    i have done simulation and calculation. I would like to know whether my calculation and simulation are right. I have attached my calculation and simulation result please help me I am stuck. Please give me some ideas. thank you
  2. Ron H
    Apr 14, 2005
    7,050
    657
    MOSFET turn on and turn off are controlled by the gate voltage, as I'm sure you know. I couldn't find any mention of gate voltage in yourr PDF.
  3. sizzhon
    Mar 25, 2012
    5
    I used 5V 94kHz pulse to gate. in practical MOSFET (VDS)is like bouncing.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    In your schematic, you show an IRF540 which is not a logic level MOSFET, but a standard level MOSFET; it is only considered fully turned ON when Vgs=10v.
    You don't show what you are driving the gate with. An IRF540N has a total gate charge (Qg) of 71nC, which won't be trivial to drive at 94kHz. There are many more modern MOSFETs that you could have chosen, with a far lower Qg.
    sizzhon likes this.
  5. sizzhon
    Mar 25, 2012
    5
    Thanx for the help. I simulated the circuit again using logic MOSFET (IRLI530N) and MOSFET Driver (TC4427). I have attached the circuit simulation and result please have a look and suggest me. that would be very helpful.
    thank you
  6. Ron H
    Apr 14, 2005
    7,050
    657
    A 2kΩ gate resistor is way too high. 2kΩ*2.5nF=5usec time constant. Your period is only ≈10usec. With 80% duty cycle, you have minimum pulse width of about 2usec. Make the gate resistor 47Ω or less. 10Ω might be better. Mount the resistor as close to the gate as you can get it.
  7. sizzhon
    Mar 25, 2012
    5
    thanx. i understand what you did. but does it give me current of 1.7mA. in another words how do i select the resistor for driver to give me the current i want and also less time constant plz.
    thankyou
  8. shortbus
    Sep 30, 2009
    4,098
    1,698
    Read this Application Note, even if your not using IRF components, the basic working is the same in all brands of drivers. http://www.irf.com/technical-info/appnotes/an-978.pdf Section #6 is the part about gate resistors and layout.
    Other component manufactures also have similar App notes.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    The gate resistor should not be used to determine current. Gate resistors are there only to prevent parasitic oscillations in the MOSFET. They need to be low value, so that rise and fall times are fast, which minimizes wasted power.
    Where do you want 1.7mA to flow?
  10. sizzhon
    Mar 25, 2012
    5
    tell me if i am doing wrong. to find out the rg (driver resistor),
    QG(total gate charge) =C×V
    C=QG/V [V=VGS(gate to source voltage)]
    C=(15×10^-9)/6 [found QG from data sheet of mosfet]
    C=2.5nF
    and then
    I=C dv/dt
    where dt= desired time to charge the capacitor for e.g.
    if we want it to charge in 10 ns then
    I=(2.5x10^-9)x(6/(10x10^-9))
    I=1.5A. since VGS=6V,
    Rg=6/1.5A
    Rg=4 ohm
    is my calculation is right? Please tell me
    thank you
  11. Ron H
    Apr 14, 2005
    7,050
    657
