Help with rewinding inverter transformer
Discussion in 'The Projects Forum' started by darryl, Oct 18, 2009.
  1. darryl
    May 1, 2009
    14
    Hello. I have taken a standard old 1kva microwave transformer and removed both coils. I want a 24v centre tapped primary and a 50v secondary and rated for about 500va. Can anyone please tell me the best gauge wire to use and the turns ratio? Any help would be truly appreciated. I hope it`s as simple as that. If not, well, that`s ok...
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Is it a steel core unit? What are the physical dimensions?
  3. darryl
    May 1, 2009
    14
    . It is a steel unit. It is 9.36 * (10^-4) m^3
  4. darryl
    May 1, 2009
    14
    Does anyone else want to have a go at this?
  5. shortbus
    Sep 30, 2009
    4,096
    1,692
