Help with replacing a CMOS LDO Voltage Regulator
Discussion in 'General Electronics Chat' started by dokworm, Oct 2, 2010.
  1. dokworm
    Oct 1, 2010
    5
    G'day all.
    I don't know much about electronics except how to solder, and I have killed a DVD-ROM drive by plugging it's power supply in backwards.
    Looking at the main board on the drive, a component has burned out which appears to be an A8805 3.3V voltage regulator. It is an SMD part that I am unlikely to be able to purchase, I was wondering if I could wire in a standard sized off the shelf regulator.
    This is the datasheet for it, is either the AME8805AEFTZ or AME8805AEFT, it is hard to tell as it is a bit charred.
    http://www.datasheetcatalog.org/datasheet/ame/ame8805.pdf
    It is a specific DVD-ROM drive, and I can't get a replacement, so I have to attempt a repair. Any help much appreciated.
  2. retched
    Dec 5, 2009
    5,201
    313
    dokworm likes this.
  3. dokworm
    Oct 1, 2010
    5
    Thanks so much, I'm in Australia, but if I can't source something local, it would still be worth it to me.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
