hi all, some of you have helped greatly with my ongoing project of a complex water level switch. With this help I have managed to add a variable delay on the relay de-energise circuit, add extra indicator leds, as well as work on EMC preparation.
There is one thing that would finish off the unit perfectly. A remote display option.
At present 4 daughterboards feed a local display board with 3 leds per daughter board. The latest arrangement has 1 green led for water, 1 red led for steam and 1 amber led for fault. If a daughterboard is set to be normally sensing water and it is sensing water, the green led will be lit only. If the board is set to be normally sensing water but is sensing steam then the red led will be lit and the amber led will be lit.
So there is a total of 12 leds. Each daughterboard connection to the local display has 12v+ connection and one 0v connection per led. This gives 16 connections to local display. I am trying to figure out the best way to replicate the display remotely without having to run a 16 core cable. The remote could be 500m away. The solution would ideally be cheap to implement and only use 4 to 6 core cable as well as being EMC friendly.
Any ideas would be great.
