help with relays please
Discussion in 'The Projects Forum' started by bowlingo, Mar 10, 2012.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I am hoping someone can point me to some good quality relaible relays...
    I am after a 12V DC coil - 230V AC 15 to 20A max current of the DPDT type. I am preferably looking for the ones I can push the pins into a piece of stripboard and solder
    I am also after a 230V AC coil - 230V 10 - 15A max current of the DPST type...again I am looking for ones I can push into stripboard/prototype board and solder
    I am in the UK
  2. #12
    Nov 30, 2010
    16,703
    7,341
    Not likely. 20 amp relays typically use .156" or .25 inch connectors (in USA). You just can't reliably jam 20 amps through a wire 1mm in diameter, so they don't build 20 amp relays like that.
  3. k7elp60
    Nov 4, 2008
    479
    69
    As an alternative, there are a lot of relays that have sockets for them so instead of strip board you could use sockets.
  4. bowlingo
    Jun 29, 2011
    162
    Just looking at the plug in power relays...trouble is I cant find a 12V coil with 15+ Amps and 230/240/250V load contacts
    I havent really looked but im pretty confident I will find some with a 230V coil and 10A 230/240/250V contacts
  5. BSomer
    Member
    Dec 28, 2011
    433
    106
    How about these?
    http://www.newark.com/finder/66-22-9-012-0000/relay-pcb-dpdt-30a-12vdc/dp/35M2031
    Had a quick look at the data sheet and there seems to be a little oddity about the current rating. The NO rating is 30A/50A max and the NC rating is 10A/20A max. Not too sure what is going on there, but they somewhat meet your requirements. I'd be careful with putting that amount of current on a stripboard though.
  6. bowlingo
    Jun 29, 2011
    162
    This is prooving to be a real pain..just spent another 45mins looking. if not DPDT then DPNC is what I could go for but the NC must be around 15A
  7. bowlingo
    Jun 29, 2011
    162
    Had to do it a different way where I use an extra relay so it can be done with 2 x 12V and 2 x 230V relays. I got the plug in power relays as they look like they have screw terminals and I should be able to stick them to the back of the box
