djsfantasi
- Joined Apr 11, 2010
- 9,163
Why are any caps necessary? We're driving a relay coil which doesn't require filtered power.
au contraire mon frere, DC relays do not have the copper shorted turn like AC relays do. They buzz loudly if not fed filtered DCWhy are any caps necessary? We're driving a relay coil which doesn't require filtered power.
Their inductance is much higher than a small relay......
Heavy current DC brakes and clutches have been used for years in industry without the use of capacitors.
Max.
Je l'ai! Learn something new every day. Relays buzz when you don't expect them to.au contraire mon frere, DC relays do not have the copper shorted turn like AC relays do. They buzz loudly if not fed filtered DC
Since the TS is building a tester for (among others) DC relays, wouldn't it be better to drive them with DC?One experiment I did once was to time the delay of a small control relay fed from a unfiltered supply at switch off, but had a BEMF diode across the coil, I don't recall the actual time, but it greatly exceeded 8msecs.
Also no audible or visual chatter was seen.
Max.
by Aaron Carman
by Jake Hertz
