Help with Reformatting, BIOS and Linux
Discussion in 'Computing and Networks' started by Sparky49, May 5, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    Hi chaps,
    I've been given an old computer (HP Pavilion) which runs Windows 98.
    However, I want to install Codewarrior, but it needs versions 2000 or higher - and I ain't paying for that!:D
    I've decided to give Linux a try, and I 'm starting off with Ubuntu.
    However, before I reformat the hard drive I've got a question.
    I'm guessing I need to format in BIOS, but after I reformat, won't the CD driver be lost?
    If so, will I have to re install the driver software before Linux? Is there somewhere I could find it, as I don't have it.
    I've downloaded Ubuntu and put it on a CD R, but there is no place for USB or anything else. I presume there is no other way to install it other than CD, but if I have no driver then it won't work at all. :(
    I eagerly await your advice, :)
    Sparky
  2. nerdegutta
    Dec 15, 2009
    2,566
    806
    Hello.
    You should check to see if you can boot from the CD-rom from BIOS. If not, you should download the Windows installer:
    http://www.ubuntu.com/download/desktop
    Try it out on a LiveCD first.
    Good luck.
  3. Sparky49
    Jul 16, 2011
    835
    417
    How do I check that?
    (Many thanks for the super quick answer!)
  4. nerdegutta
    Dec 15, 2009
    2,566
    806
    When the computer start, a quick moment, it should display a message on how to get into BIOS. I'll guess it's the DEL - key. Inside BIOS, navigate to the BOOT options, or boot sequence or something like that. If it can boot from CD-rom, it should be listed there.
    Or it could be the F2-key
  5. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
  6. PatM
    Dec 31, 2010
    81
    72
  7. Sparky49
    Jul 16, 2011
    835
    417
    Would that Jolicloud work with Codewarrior?
    Also, this computer doesn't have internet access. Would it still work?
  8. nerdegutta
    Dec 15, 2009
    2,566
    806
    If it's based on Ubuntu, I think you'll have a choice during setup. To install it side-by-side with Windows. Just like a Dual Boot. But you need to have free diskspace...
  9. Sparky49
    Jul 16, 2011
    835
    417
    Well, i just checked the BIOS.
    In the boot selection menu, it had a ALTAPI CDROM option (something like that), but i couldn't open it like the hard drive option, and I couldn't add a + or - liek I could to the hard drive.
    What does this mean?
  10. nerdegutta
    Dec 15, 2009
    2,566
    806
    Have you tried to boot from the CD?
    If you insert the cd, and reboot, try hitting the F12 key. A boot menu might appear, and you can choose your boot device.
  11. nerdegutta
    Dec 15, 2009
    2,566
    806
    Did you manage to install Linux?
