help with reflow unit
Discussion in 'General Electronics Chat' started by lokeycmos, Mar 31, 2013.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    the other day my yihua 8508D heat gun stopped working. the display comes on,but no heat or air flow. I have verified that the air pump works outside of the unit. there is some info on the unit here:
    http://www.alibaba.com/product-gs/216305021/YIHUA_8508D_diaphragm_pump_Hot_Air.html
    it says that the heating element is supposed to be 90 ohms, but im measuring 20 ohms. I removed the connecter where the heating element connects to the circuit board. I measure 120v across the two connectors,but when I reconnect the heating element I only measure a few volts AC.
    im thinking that there may be more than one issue. does anyone have any advice or pointers for me? also, anyone know where I can get a schematic for it? thanks!
  2. ErnieM
    Apr 24, 2011
    7,436
    1,626
    Last time I used my hot air pencil I forgot about the magnetic holder it needs to be in to start, does yours have one?
    If it's not something simple then it's a lot of grunt work if you don't have a schematic to follow.
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    Follow the heater wires back to the pcb, i bet they go to the Triac {on the heatsink top right pcb} and {opto coupler white 6 pin chip Moc3041}
    There is an LM358 dual op amp that will be the thermostat, prob using a thermocouple in the heating element also.
