Help with reading a circuit
Discussion in 'The Projects Forum' started by hrs, Apr 18, 2015.
  1. hrs
    Jun 13, 2014
    86
    7
    I would like to make a sine wave generator as described here:
    http://www.bobsdata.com/audio_sine_wave_generator/index.html
    What I dont understand from the schematic is how the dual potmeter (R5) is connected. Are the 3rd terminals of each channel of the potmeter connected to each other via the dashed line or something like that?
  2. Dodgydave
    Jun 22, 2012
    5,166
    775
  3. djsfantasi
    Apr 11, 2010
    2,911
    881
    No. The third terminals are left disconnected. The dashed line indicates that R5 is a dual pot.
  4. MrChips
    Oct 2, 2009
    12,648
    3,459
    What is shown is called a "ganged pair of pots" or "ganged pots". There is no electrical connection between the pots. The purpose of the dashed lines is to indicate that they share a common shaft. The two pots are mounted on the same shaft so that the control knob turns both pots equally at the same time.
    A common usage of ganged pots is in the volume and tone controls of stereo audio amplifiers.
  5. hrs
    Jun 13, 2014
    86
    7
    Ah, of course! Thank you :)
