Help with Radio Shack Lab
Discussion in 'General Electronics Chat' started by Nazgul666, Jan 24, 2015.
  1. Nazgul666
    Jan 24, 2015
    So I read through a lot of the tutorials on this site after I happened upon it. It really inspired me! I bought the Radio Shack Electronic Learning Lab and completed the first project. It worked fine. However, I really want to understand the schematic. It confuses me because it looks like it has 3 power sources.
    The other issue is, I don't understand how what I built on the breadboard corresponds to the wiring diagram, specifically the function of the jumper wires. Is anyone familiar with that particular project?
    Thanks,
    Mike
    ErnieM likes this.
  2. spinnaker
    Oct 29, 2009
    5,063
    1,160
    It might help if you posted the schematic. Even if someone here has that lab, chances are they have not looked at it in years.
  3. Nazgul666
    Jan 24, 2015
    Woops. Sorry
  4. #12
    Nov 30, 2010
    16,663
    7,308
    2 answers with one sentence: The board has labels for other voltages but they are not connected to anything unless you use a wire to connect them.
  5. Nazgul666
    Jan 24, 2015
    Cool, thanks. Bear with me as I go step by step.. So does the current start at the 4v section on top, and then that white jumper brings it down?
  6. MrChips
    Oct 2, 2009
    12,623
    3,451
    It says so in the manual "Note that the 6-volt battery is replaced by symbols."
    This means that every point in the circuit diagram that is labelled +6V is connected to the same +6V terminal on the battery or power supply.
    On your kit, V4 is also labelled 6 Volts. Anything that is plugged into one of those 5 holes in a row is connected to the +6V terminal on your internal power supply.
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    That page of a book that was posted shows a very slapdash way of drawing a schematic - it makes it harder to follow what each component does.
    Take a sheet of paper and draw the battery negative across the bottom and the battery positive along the top. Draw the chip between those 2 lines and set about filling in the components from the original drawing - that's a pretty good practical exercise for starters.
    It might be worth doing a search for schematics in general and browsing the results just to familiarise with how most people draw them.
  8. Nazgul666
    Jan 24, 2015
    Guys, thanks. That makes sense that everything plugged in to that that top voltage section gets power. And I guess those cris crossed jumpers over the 555 chip somehow connects those sections across the rail. I guess I was looking for a point by point mapping of the current flow like the simple series circuits in the tutorials. Bit I think with these breadboards it's a little different. Maybe not as linear.
  9. MrChips
    Oct 2, 2009
    12,623
    3,451
    What you see on your breadboard is one white wire connecting pin-8 of the 555 chip to +6V.
    Then you need another white wire to connect pin-4 of the chip to the same +6V.
    You can do that by connecting to V4 or you can do that by connecting to pin-8. Same difference. The choice is yours.
