Help with question
Discussion in 'Homework Help' started by purecilia, Dec 29, 2008.
  1. purecilia
    Dec 29, 2008
    12
    i need more explanation please !!!!!!!!!!!!!!!!
  2. purecilia
    Dec 29, 2008
    12
    i also cannot understand this question can someone please explain it well !!
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We prefer that you always place your questions in a new thread instead of hijcaking ang existing one.
    This is the original - http://forum.allaboutcircuits.com/showthread.php?t=17487.
    The question is quite simple. There are two voltages, but there is only one net potential difference. Subtract the lowest voltage from the highest to find it.
    After that, it is a simple series circuit. There is a drop across the diode which affects the voltage across the resistor. Once you work that out, it is obvious what the total current is, and the rest of the answers become easy.
