help with pwm output
Discussion in 'The Projects Forum' started by ak11667, May 28, 2012.
  1. ak11667
    May 28, 2012
    i have a computer controlled PWM
    problem i have is it pulses the ground signal, and i need it to pulse the positive
    is there any way i can design a simple circuit to switch them while still maintaining the pwm pulses, i was thinking of using a TIP31c transistor, but i cant get it working right
  2. absf
    Dec 29, 2010
    1,493
    374
    Show us your schematic so we can help with the connections. Should be easy as you just need an inverter.
    Allen
