help with PWM circuit for PIC16f877A
Discussion in 'Embedded Systems and Microcontrollers' started by switmira, Jan 25, 2010.
  1. switmira
    Jan 20, 2010
    hii...i am doing my final year project regarding boost converter..the PWM is produce using pic16f877A..i have to use picbasicpro languange..i need to produce frequency of 45kHz with 50% duty cycle..below is the coding ..really need help...
    TRISC.2 = 0 ' CCP1 (PortC.2 = Output)
    PR2 = 110 ' Set PWM Period for approximately 45KHz
    CCPR1L = 55 ' Set PWM Duty-Cycle to 50%
    CCP1CON = %00001100 ' Select PWM Mode
    T2CON = %00000100 ' Timer2 = ON + 1:1 prescale
