Hi!!
I need to design a sensing system using the PT 100. My sensing range is 30 to 50 degree centigrade.
Using a 1ma source which is recommended, the voltage drop across the PT 100 is 0.11167vfor 30 degrees (resistance is 111.67ohms) and 0.1194 for 50 degrees (resistance is 119.4 ohms). My ADC has a analogue range of 0 to 3.3 v.
Using the y-=mx+c formula, I get a gain requirement of approximately 427 and a offset adjustment of - 47v approximately.
The values for gain and offset are too high. Can you please help me in designing the signal conditioning circuit.
Cheers
Aquib Fateh
Cheers
Aquib Fateh
