HELP with Power Window :/
Discussion in 'Embedded Systems and Microcontrollers' started by glenn_pangfb@yahoo.com, Feb 5, 2012.
  1. glenn_pangfb@yahoo.com
    Feb 3, 2012
    7
    I got a 12v power window controlled by a relay. i want to vary its speed but i failed when i used a potentiometer and it then SPARK! wooo... why does this happen.. please help to control the speed of a power window.
  2. R!f@@
    Apr 2, 2009
    8,789
    771
    Hee hee hee..Power window motor draws more current than ur every day motor.
    Still a pot with a tiny motor will give u smoke.
    U have to PWM drive that motor and it won't be cheap. cause 'em window motors are pretty hefty
  3. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Also, is the window motor still in the car?
  4. MrChips
    Oct 2, 2009
    12,633
    3,453
    Hee, hee. You'd better say NO otherwise you know what will happen.
  5. R!f@@
    Apr 2, 2009
    8,789
    771
    hush ! Guys .
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Was trying to avoid the hint. He could just say no anyway and get all the help he needed, even if it was still in the car. Unless the mods are feeling particularly daring, I wouldn't be surprised if this thread gets locked.
    Glenn, automotive discussions are strictly forbidden here at AAC, due to various safety and liability issues. We highly recommend you avoid any projects that change anything in a car because it could have unwanted side-effects that could lead to dangerous situations. If you choose to go ahead with it, I'm afraid we can't help you. We do not want to participate in a project that could endanger your life. I hope you understand.
    Regards,
    Der Strom
  7. glenn_pangfb@yahoo.com
    Feb 3, 2012
    7
    i posted it here because i used pic16877a to control it with l293d as the driver-. it is used as a wheel of my project, but when i apply the 12Vdc the resistor actually spark, i joked myself "does potentio really light up" XDD:eek::eek:
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It would help if you posted a schematic of what you already did. It sounds to me like you're putting too much current through the pot. That's a great way to fry it. We need to know what you've actually done before we can tell you what's wrong, or how to fix it.
