Help with port setting during an interrupt service
Discussion in 'Embedded Systems and Microcontrollers' started by goahead113, Nov 19, 2014.
  1. goahead113
    Dec 6, 2010
    Hi all, I've almost completed a program for a pic12f675 to monitor series connected lithium batteries and enable outputA when they are within set levels and also enable outputB using an IOC interrupt when an input hi triggers the service to run then disable outputB when input is released then return to normal routine.
    Basically when the outputb is enabled during interrupt it clears the input pin state causing the loop polling of the input to fail and exit from interrupt prematurely. Asm file is attached but here is the basic lines the i'm having problems with. Thanks in advance for any help.
    Start
    org 0x0000 ;program starts at location 000
    goto Setup
    org 0x0004
    nop
    bsf GPIO,2
    call del_0
    btfsc GPIO,3
    goto $-2
    bcf GPIO,2
    bcf INTCON,0
    retfie
    SetUp
    bsf STATUS,5 ;bank 1
    movlw b'00010011'
    movwf ANSEL ;
    movlw b'11100000' ;,
    movwf OPTION_REG
    bcf STATUS,5 ;bank 0
    movlw 07h
    movwf CMCON ;
    bsf INTCON,3 ;IOC interrupt enable
    clrf ADCON0
    Clrf PIR1 ;CLEAR ADC interrupt FLAG BIT
    bsf STATUS,5 ;Bank 1
    clrf VRCON
    movlw b'00001000'
    movwf IOC ;SET ADC INTERRUPT
    clrf PIE1 ;SET ADC INTERRUPT
    movlw b'00001011' ; Set GPIO INPUTS
    movwf TRISIO
    ;calibrating the internal oscillator
    call 0x3ff ;get the calibration value
    movwf OSCCAL ;calibrate oscillator
    clrf GPIO ;Clear GPIO
    call cutselect
    goto Main
