Help with PIC16f877a-i/p
Discussion in 'Embedded Systems and Microcontrollers' started by Oretega, Jun 4, 2008.
  1. Oretega
    Jun 4, 2008
    I have made a script to Power up 2 7 segment displays (common anode)
    with
    Port A to control the common anode part using a 2N3906 pnp BJT.
    Port B power up the cathode part of the 7 seg.
    Is this script correct? Its my first time programming one, and none of the lights light up. I am having a headache now. lolz.
    ; Pressure Sensor Program ;
    ; Oretega 6/4/2008 ;
    list p=16F877A
    #include p16F877A.inc
    ; The start of the main program
    Main:
    __CONFIG _CP_OFF & _WDT_OFF & _HS_OSC & _LVP_OFF & _BODEN_OFF
    org 0
    PORTA equ 00h
    PORTB equ FFh
    END
  2. mik3
    Feb 4, 2008
    4,846
    63
    First you have to set the oscillator frequency and setup your timers. Then set which I/O you want to be inputs and which to be outputs. Also you have to use a while condition like this
    while (true)
    your code
    to have an infinite loop of operation.
    Look at this website http://www1.ceit.es/asignaturas/robots/datasheets/CCS.pdf
    It says the instructions to program in C language
    Here is a part of the beginning of a program of mine in C:
    #include <16f819.h>
    #fuses NOWDT, INTRC_IO, NOPUT, NOMCLR, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG, NOPROTECT
    #use fast_io(A)
    #use fast_io(B)
    void main()
    setup_oscillator(OSC_8MHZ);
    set_TRIS_B(0b00000000); //determine which pins are inputs and which are outputs
    set_TRIS_A(0b00111111);
    SETUP_TIMER_0(RTCC_DIV_128);
    setup_timer_1(T1_DISABLED);
    setup_timer_2(T2_DISABLED,0,1);
    while (true)
    your code
  3. Oretega
    Jun 4, 2008
    I have learned c++ in college 2 years ago, quite blurry in my mind now. But think it will be easier than assembly language. Can teach me how to use it with mplab?
  4. mik3
    Feb 4, 2008
    4,846
    63
    Read the attached pdf file.
