help with pic programming
Discussion in 'Embedded Systems and Microcontrollers' started by markosillypig, Jan 16, 2009.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all i have bought a jdm programmer to program some 12f629 pic chips
    i am using winpicpgm to program the chips but on my programmer i dont know where the chip goes
    anyone help please
      File size:
      14.9 KB
      26
  2. mik3
    Feb 4, 2008
    4,846
    63
    What is your question?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Be aware that the PIC must be properly oriented. Read the accompanying literature very closely.
  4. markosillypig
    Jul 21, 2008
    184
    hi how do you add a asm file to a chip is it in the same way as a hex file??
    thanks all
  5. AlexR
    Jan 16, 2008
    735
    54
    The simple answer is you don't.
    The .asm file is a text file that the assembler/linker uses to produce the .hex machine language file that is loaded into your chip.
