Ernie, yes Freerouting.net is what FreePCB uses. Somehow it functions interactively between the user's computer and some other computer over the Internet using Java; I think the other end of the line is in Germany. I don't know how it works but as a user, I don't need to care.
DerStrom, you can set the minimum trace spacing for the autorouter, and of course the board manufacturer will tell you what they're able to produce, so you have to be aware of that issue. I assume every layout program has a rules checker which verifies this for you. I don't think the layout is unduly convoluted, but as I said, for this type of design it's not critical. My initial prototype was hand wired on perfboard, and if that works, just about anything will! Really, a lot of electronic designs don't require much more than getting traces between defined sets of pins. If I were doing a sensitive analog project or high-speed digital, or RF, I'd have to pay more attention to what was going where.
You didn't respond when I asked you to guess how long that layout would take if you did it manually! Would it be time well spent, if there were an easier method which produced a working board?
