Help with Optical sensor
Discussion in 'The Projects Forum' started by spelcaztr, Dec 19, 2011.
  1. spelcaztr
    Feb 16, 2011
    12
    Hi guys. I have been working on my project. Something that could detect incoming intruders in the house. is there a way to make an optical sensor to detect as far as 1m? I looked up some of the sensors in the market but a lot of them can only detect as far as 2mm. Or is there a better way? The sensor output should be able to activate a relay in so the output should be approximately 6v min.
    Thanks.
    i think this works but it functions as a sound/tone detector or something.
    http://www.aaroncake.net/CIRCUITS/irremote.asp?showcomments=all
  2. praondevou
    Jul 9, 2011
    2,936
    489
    The receiver is tuned to only respond to incoming infrared light modulated at the specified frequency, since he says tone I assume it's audio frequency. It could work like a light barrier. Which brings us to a fundamental question.
    Do you want to detect someone approaching or do you want to detect someone passing through a light barrier?
    One works with reflection, the other one on interruption of a light beam (pulsed or continuous).
    Ambient light sources can be a quite challenging issue to resolve. Is this going to be installed where ambient light changes rapidly? (like direct sunshine with passing by clouds)
    Have a look at the SI1102. You might be better off with ultrasound modules.
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    I've seen barrier alarms working indoors really well using a sender and receiver pair pointing at a corner reflector (prism type, like the ones on vehicles). I think the optics use collimating lenses though. Security companies must use loads of these things.
  4. Bernard
    Aug 7, 2008
    4,240
    414
    Passive infra red, PIR, detectors are quite reliable, & good for several meters.
