Help with obtaining a specific pulse
Discussion in 'Homework Help' started by Malsch, May 18, 2011.
  1. Malsch
    Mar 19, 2011
    23
    Hi, I have a 1Hz pulse and wish to obtain a very short pulse at the low edge of the 1Hz pulse. The following is what I'm referring to:
    Since I cannot use a capacitor, I was thinking maybe something with flip flops but I'm still a bit stuck.
    Thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps you could define "very short"? Is that pulse in the range of a one shot?
  3. shortbus
    Sep 30, 2009
    4,086
    1,665
  4. ErnieM
    Apr 24, 2011
    7,434
    1,625
    It ain't pretty and may need some serious tweaking. I did this many years back, I don't remember did I actually use a gate or did I build this up with transistors and a diode AND function but here goes.
    Two inverters in series will have a brief moment when the input rises where both outputs are low; also a brief moment when the input falls where both are high. If you can catch that event you have an edge detector.
    Well you said no caps!
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you intervene a capacitor between pin 4/9 and Ground maybe you could prolong the charging delay of the second NOR gate.
    I haven't tested it, talking completely based on taught stuff.
    I know you said no caps, but maybe you weren't referring to such an application. Alternatively, since the theory is to increase the load of the second NOR gate, you could just try to drive more IC inputs with it, just to increase the load it "sees", without any other logical effect.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    If the resulting pulse is too short, any odd number of gates (inverters) in series will produce the same result, with the resulting output pulse width being equal to the propagation delay of one inverter, multiplied by the number of inverters in series.
