Help with nonlinear resistor
Discussion in 'Homework Help' started by bluebird, Apr 8, 2008.
  1. bluebird
    Apr 8, 2008
    Hi all,
    I'm trying to solve the following problem:
    "A resistor R and a capacitor C are in series with a battery of constant voltage V0. Suppose that the gate is closed at t = 0, and that there is no charge on the capacitor initially. Let Q(t) be the charge on the capacitor at time t >=0. Derive the circuit equations."
    The twist is that there is a nonlinear relation between voltage and current, that is, the current flowing through the resistor is given by the general function I = g(V) rather than the usual I = V/R. My question is, can Kirchoff's voltage law still be applied in this case, or does that only work for a linear problem? Thanks for any help you can provide!
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    In a complete circuit Kirchhoffs Voltage Law always applies.
    Dave
  3. scubasteve_911
    Dec 27, 2007
    1,202
    Yes, Dave is correct, you can always apply a circuit analysis law, since it is true for all of time.
    You're right about the non-linear relationship. This calls for a "time-domain solution" where t is the input to your final equation. Whatever variable you choose to isolate, you should be able to find it as a function of t. Your time domain solution will consist of two parts: transient and steady-state.
    The transient solution will disappear as t approaches infinity, unless it is an unstable circuit. The steady-state solution will be left.
    Since I don't wanna get into the math on here, I found something that will help you.
    http://www.eas.asu.edu/~holbert/eee202/EEE202_Lect12_DiffEqSolutionTransientCircuits.ppt
    Steve
