i have a tecktronix scope model 564. last night when i turned it on i hear a soft pop sound and a flash on the side of the scope. but it still operated. the same thing happened this morning, it still worked. the wierd thing is that the power indicator was still on even though the switch was in the off position. the power switch feels solid with no play in it. now the scope wont power on at all. i took the side off, and found a fizzled capacitor. could this single cap be the cause of my problems? also, if you look at the pic of the side i attached, i noticed a few neon bulbs as part of the circuitry. what are these for? what do they do? thank you!
