help with my rectifier to two smaller circuits
Discussion in 'The Projects Forum' started by keithisdoped, Aug 26, 2011.
  1. keithisdoped
    Aug 22, 2011
    14
    hi in this schematics you can see i have made a dice game , a buzzer and a rectifier. i designed the dice and buzzer separately from the rectifier.
    after the designs were done i tried combining the rectifier to the dice and buzzer circuit but every time i trial run it, the rectifier blows in multisim , what am i missing? or what have i done wrong? anyway the 5MR is there to decrease the 9v to 5ish V for the 4017 ic.
    this is my final year project and requirement of 3 different circuits thus the separation of lot's of things.
    i would really appreciate the help! thanks geniuses :D
  2. ian123
    Member
    Aug 24, 2011
    73
    Are you saying the rectifiers D7 to D10 blow up
  3. keithisdoped
    Aug 22, 2011
    14
    oops i meant transformer damn sorry it's like 2am here and i'm rushing through my project...
  4. ian123
    Member
    Aug 24, 2011
    73
    So the transformer blows up
  5. ian123
    Member
    Aug 24, 2011
    73
    or the fuse blows
  6. keithisdoped
    Aug 22, 2011
    14
    the fuse stays but the transformer blows like in the pic.. the output of transformer is gone lol.
  7. ian123
    Member
    Aug 24, 2011
    73
    possibly the transformer is connected the wrong way ie: secondary on mains side. the rest of the circuit is ok
  8. ian123
    Member
    Aug 24, 2011
    73
    C4 should be a little lower 0.1 uf like C5
  9. keithisdoped
    Aug 22, 2011
    14
    it was initially suppose to be 0.33uF but i bought 0.33F without looking and so i thought the nearest to 0.33uF was 1uF which i had extra thus soldering it in haha.. anyway i just changed C4 value doesn't seem to do a difference..
    nah it's connected correctly because when i remove the rest of the circuit , the rectifier works...
  10. ian123
    Member
    Aug 24, 2011
    73
    No it wont C4 and C5 are for transients and is recommended by the manufacturer.
    apart from that i dont see anything wrong with your circuit.
    if you want you could simulate just the rectifier circut thn see if the transfomer blows
  11. ian123
    Member
    Aug 24, 2011
    73
    Sorry beats me everything looks good
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If it is actually a 0.33 Farad capacitor, then it is VERY large. It may have a low voltage rating. If the voltage rating on the 0.33F cap is low, it will look like a short to the transformer output.
