Help with Mux Truth Table & Wave Form
Discussion in 'Homework Help' started by gammaman, Feb 19, 2009.
  1. gammaman
    Feb 14, 2009
    29
    I have to following code for a Mux and it complies. When I go to the wave form it simulates perfectly. Thing is, I do not know what I am looking for, to see if it is correct.
    Here is the code
    Code ( (Unknown Language)):
    1.
    2. [FONT=Arial]Library ieee;
    3. Use ieee.std_logic_1164.all;
    4.
    5. Library ieee;
    6. Use ieee.std_logic_1164.all;
    7.
    8. Entity Mux is
    9. Port(
    10. D : in std_logic_vector(3 downto 0);
    11. S : in std_logic_vector(1 downto 0);
    12. Y : out std_logic);
    13. End Mux;
    14.
    15. Architecture Joe_Structure of Mux is
    16. Begin
    17. with S select
    18. Y<= D(0) when "00",
    19. D(1) when "01",
    20. D(2) when "10",
    21. D(3) when "11";
    22. End Joe_Structure;[/FONT]
    23. [FONT=Arial][/FONT]
  2. mentaaal
    Oct 17, 2005
    451
    Do you understand how a MUX works? If you do then you should be able to see from the timing waveforms if the operation is working properly or not.
  3. veritas
    Feb 7, 2008
    167
    You're look for:
    1.
    2. Y = D(0) when S = "00",
    3.     D(1) when S = "01",
    4.     D(2) when S = "10",
    5.     D(3) when S = "11";
  4. tuborggg
    Jan 3, 2009
    37
    what you're missing is a TEST-BENCH -
    Another code which has your MUX as a component, and generates clock and reset (you can skip it because it's an Asynchronous module, your mux), and changes the inputs to your mux, and checks its outputs....(that's why you DO need clock and reset, for the changing it time)
    Have fun.
