Hi all electronic gurus.
Today i want help with multiplexers.
Task 1.
Draw logic diagram for a multiplex, which has input signal A and B, and control signal S. The output
bait included with U. multiplexes to be built with as few two-inputs NAND-gates
as possible. It shall apply to the output Y = A for S = 1 and Y = B for S = 0.
Task 2.
To a four-to-one (4:1) multiplex is input I3 I2 I1 I0 connected. Selection signals are S1
and S0, where S1 is the most significant bit. Enter the Boolean expression for output signal U, then
insignalena I3 I2 I1 I0 linked by:
I3 3, I2 to 2, I1 to 1, and I0 to 0.
Note:. Multiplex has inputs 3, 2, 1 and 0
Thanks in advance!
Best regards Arcsky
Task 1.
Task 2.
Thanks in advance!
Best regards Arcsky
