I am new to the site but not to electronics. I took electronics at school quite a few years ago now. I can read diagrams and soldier but for what I have in mind is far past my knollege. The following project is for the purpose of Airsoft (Paintball with out the mess).
Objective:
To build x1 wireless display device and x3 wireless motion sensors.
The Display Device:
The display device needs to be as small as possiable, light and fitted to my wrist. It should have a vibration alert everytime a sensor is tripped and indicate which sensor via a lit LED. Once the sensor is tripped the LED should stay on and the unit should only vibrate once.
The Sensors:
The sensors need to be fairly small and light.
Have no LEDs on them to give away their position.
The 3 sensors ideally need to be a single IR laser beams ( to put accross doorways). If possiable I would prefere if there was not another unit on the other side that the laser makes contact with.
Thank you for your help.
SiLK
Objective:
The Display Device:
The Sensors:
SiLK
