I'm trying to drive an IRF530 power MOSFET from a 5V arduino output. I'm using the transistor to momentarily switch a load connected to a car battery (12V). My problem is that the IRF530 requires at least 7V to fully "turn on," and the arduino's 5V is too low.
How would I go about making a driver circuit from the 12V power supply and the arduino's 5V output? I have several PNP and NPN small-signal transistors and resistors to work with.
Thanks for the help,
bk8190
bk8190
