Help with Moore FSM
Discussion in 'Homework Help' started by Hazard*, May 26, 2015.
  1. Hazard*
    May 26, 2015
    I tried to draw Moore FSM that accept sequence 111101 but I'm not sure if it is right
    here is my solution
  2. tshuck
    Oct 18, 2012
    3,531
    675
    What is meant by non-overlapping? I'm sure if you ask three different people you'd get three slightly different answers. Your answer will affect the way your state diagram should look...
    Two things I see are:
    1. The last state, S6, has no definition for what happens when in that state and the input is 1.
    2. What is being stated in the lower half of the state? In a Moore machine, it is the output value, are you stating that Z=x, where x is the output value? It looks like it could be 20 and 21. You should explain your system before you ask if it is correct.
  3. WBahn
    Mar 31, 2012
    18,064
    4,904
    A couple other things to note:
    Assuming that Z0 means to output a '0' and Z1 means to output a '1', then why do you have z1 as the output condition for S5?
    Leaving S5 you have two arrows, both of which are labeled '1'. Does that make sense?
