Hi!
I have a monitor that didn't want to turn on twice already in half a year time. The first time I took it home (from my grandparents apartment) and when I plugged it in it started to work. I suspected it was the cable so I changed it and when I plugged it in again where it was before it was working fine. Then it didn't want to turn on again a few days ago. I immeadeately changed the cable on the spot and it didn't work either. So I brought it home again and when I plugged it in it magically worked again. Since I read that many times its the capacitor's fault for these kind of problems I opened it up, but no capacitors are visually bad. There is however a darker area around some component that looks like it has been heating a lot. I would like to ask you if you think its worth changing the capacitors anyway or if that other component might be responsible for the trouble. The monitor is over 10 years old. Thank you for your help!
Images: https://www.dropbox.com/sh/v2t2fpyucdhxv4b/VTP_KjQ1c2
