Help with mobility scooter power
Discussion in 'General Electronics Chat' started by Robo1974, Apr 19, 2014.
  1. Robo1974
    Apr 19, 2014
    Hi
    I have recently purchased a used mobility scooter
    pro rider road king
    24v
    1100w motor
    it was the most powerfull on i could find cheaply
    my problem lies in the fact that its very hilly around here and the scooter just cant make it up the hills.
    is there anyway to increase power?
    I know that increasing voltage increases power but that also means a complete rewire i guess?
    can i upgrade the speed controller and pot? it has a 5 k pot at the moment.
    i am a newbie at modding this kind of thing but im capable of doing most things
    any ideas?
  2. inwo
    Nov 7, 2013
    2,435
    315
    I'm kind of a scooter guy.:D
    I had a similar problem with a razor mx350 for grandson. It was useless off road or on hills.
    I put a 4 to 1 gearmotor on it from a razor atv. There was no room for sprocket change. The low cost design used the smallest possible gear on motor shaft and largest on wheel.
    Look at your final drive. See if it could accommodate ratio change.
    My brother has a very similar scooter in his surplus store right now. When I get down there, I'll look at his, for ideas.
    Robo1974 likes this.
  3. Robo1974
    Apr 19, 2014
    Thanks i will have a look at the drive gear :)
  4. inwo
    Nov 7, 2013
    2,435
    315
    His is a Rietti Civic Rider. Haven't found much info on either model.
    It uses an integrated motor/differential. Not much chance of gear change, unless factory mods are available.:(
    Also tires are low profile already. Not much chance of smaller tires helping.
  5. Robo1974
    Apr 19, 2014
    Yeh dont think i want to open that gearbox! can the pot be adjusted? or will that make no difference? they are obviously set in such a way that forward gets most power could it be turned without effecting any of the other circuitry?
  6. inwo
    Nov 7, 2013
    2,435
    315
    I doubt the pot or controller can be set higher.
    You might check battery voltage under maximum load.
    Check at battery and also at controller.
    Scooter has good reviews for power and hills.
    Although scooters will shut down under low voltage conditions, I do notice a drop in speed and torque, as battery gets low, in some of my EVs.
    If it were mine I would do a full power test, by connecting battery voltage direct to motor on a hill.
    That would give a baseline maximum power level, to compare with the pwm from controller.
    I hesitate to suggest you do this as it may be difficult to do safely.
  7. Rbeckett
    Member
    Sep 3, 2010
    205
    32
    I have the same scooter and it goes over hill and dale all over our 5 acres. It climbs and pushes through the brush with no problem at all, look at the pot in the hand control to see if it is in spec or out. Too much resistance will cause the problem you are describing quite easily. Hope that helps you find the source of the issue a little quicker.
    Wheelchair Bob
    inwo likes this.
  8. shortbus
    Sep 30, 2009
    4,096
    1,692
    Is it possible some one added a resistor in series with the pot? To make the scooter more controllable for the previous owner.
