help with lm35 circuit needed
Discussion in 'The Projects Forum' started by ddonn, Feb 22, 2010.
  1. ddonn
    Feb 10, 2010
    13
    I have set up a simple temprature measurement circuit as shown in the link provided. I am using a 5V supply and a 500K resistor. At room temperature i am getting an output of .2mV instead of the approx 200mV i expected. Does the lm35 chip need to be calibrated and can anyone tell me if the circuit shown is correct?
    http://www.facstaff.bucknell.edu/mastascu/elessonshtml/Sensors/TempLM35.html
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you used Google to get a data sheet?
  3. ddonn
    Feb 10, 2010
    13
    Yes, I have a copy of datasheet. I checked the calculations for resistor values and it says to divide Vs by 50uA instead of 10E-6 stated on the circuit i constructed so i'll try that
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Ask your instructor/professor why the circuit on the website does not agree with the datasheet for the LM35.
    Ra is only used when a negative supply is also used. See page 1 of the datasheet.
  5. ddonn
    Feb 10, 2010
    13
    Unfortunately it is a research only project so help from lecturer is not an option. I need to measure in the minus degree range also so i take it i need a plus and minus supply???
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    That is correct; you need a bipolar supply. (+V and -V)
    Whatever supply you use, you will need to calculate the resistor as the datasheet states:
    R1 = -V/50uA
    So, if you had a +/-5v supply, then:
    5v/50uA = 100k Ohms - or basically, 20k Ohms per volt of -V.
    [eta]
    Actually, there are more applications circuits in the datasheet starting page 7. Figure 7 might appeal to you for its' simplicity, but the diodes' Vf will change over temperature, and I frankly doubt the circuits' accuracy. If the temp range isn't extreme or not critical, you might just ignore the variations.
    Remember that the LM35 requires at least 4v across it in order to give a valid output. A 1N4148/1N914 diode will drop about 460mV with a 50uA current, and about 380mV with a 10uA current at room temperature - so that circuit would require 5V minimum.
  7. ddonn
    Feb 10, 2010
    13
    Thanks, i'll give that a try
