I am having with the coil selection chart for the LM2675. The LM2675 is a simple switcher power convertor from TI.
My input voltage is going to be <14V and my current supplied <.2A
I need to know what coil to use. Really how to select it form this chart:
It is real obvious where you choose the max input voltage and load current but when you look to where the two intersect, I am not seeing a suggested coil. Would my coil be L11?
