I have an LED mining lamp... can be seen here:
The problem I have is after about 6 hours it just shuts off. This is obviously due to low battery voltage because if you let it sit there and dry charge itself, it will run a little while again, then shut off once more. I don't know a whole lot about electronics but since I have other LED flashlights that will run all the way until the light dims to nothing, then this light must have something in it that is shutting it down... any idea's? I would just like to force this thing to run until it fizzles out instead of it just shutting off on me.
Edit: it is li-ion powered so I don't know if that is significant in any way
