Help with Korg Monotron schematic
Discussion in 'Electronics Resources' started by nDever, May 21, 2014.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey guys,
    I'm studying the Korg Monotron schematic in my quest to get a general idea of how synthesizers may be designed.
    I have a particular question about the schematic. In the bottom left corner is the power module. Unless I'm missing something, the only source of voltage for the entire system is the two AAA batteries which is 3 volts. But if you look, they have the VCC rails labeled as +5V. Where is the additional voltage gain coming from?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Did you see IC 1 next to the battery?
    This chip acts as a boost regulator to create the 5 Volts.
    TI has some details on the chip:
    http://www.ti.com/product/tps61071
    Bertus
  3. nDever
    Jan 13, 2011
    154
    But I thought you couldn't just "generate" energy. Their boost regulator is connected to the same source.
  4. nDever
    Jan 13, 2011
    154
    Sorry for the double post, but another question is how are they powering their opamps with just a single rail?
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    IC2B is used to create the "BIAS"signal, wich functions like a virtual ground.
    All over the schematic you will see little triagular symbols that will be connected to this "BIAS" point.
    Bertus
    nDever likes this.
  6. RichardO
    May 4, 2013
    1,337
    429
    You are absolutely correct. When you step up the voltage, the available current is reduced and, so, the amount of power (energy) is the same -- minus the losses in the conversion. These losses are typically 10 to 20 %.
    nDever likes this.
